Old 10-11-2018, 02:07 PM   #3291 (permalink)
MHO: build and use it with what you have. Probably will exceed expectations. Otoh: better to fry existing silicon than go buy new expensive silicone to OOPS. Just ask thingstodo.
Old 10-11-2018, 03:37 PM   #3292 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
+1 on that. But I guess it would depend on how expensive the existing silicon is that you already own
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
Old 10-11-2018, 05:06 PM   #3293 (permalink)
Originally Posted by BogdanT View Post
On my particular application, I have some questions for the experts. I have some IGBT's lying around which I want to use for the P&S AC board running the AC35 at 144V.
They are 600V 400A Powerex CM400DY12NF and have
Sunk cost=paid for=free more or less. YMMV. WAAAY cheaper than 1800a currently on mouser
Old 10-11-2018, 05:56 PM   #3294 (permalink)
More specifically the peak values are pulse values (measured in couple of ms).
The bus-voltage pulses get reflected to a lower or higher extent when they reach the change of impedance at the motor terminals .. I think that's an acceptable translation of the sort-of understandable videos that explain that stuff ...
I have seen 2.25x bus voltage at the output terminals of the IGBTs, before the turn on/turn off resistor values have been adjusted to minimize overshoot. And 2 ms is more than enough time to blow up your IGBTs
Old 10-12-2018, 02:31 AM   #3295 (permalink)
Yes that's correct about the voltage spikes, but I was referring to the AMP draw spec on the IGBT (IC max).I'll just prototype around these for now, aiming for a current limit of 350A per phase and we'll see from there.
PS: I've also gone back to the design board a bit ... might just opt for a DC series motor for the first setup (didn't buy the AC35 yet)
Old 10-12-2018, 02:59 PM   #3296 (permalink)
I guess I read that wrong. Sorry
Old 10-12-2018, 04:58 PM   #3297 (permalink)
I wasn't very clear myself there
Old 11-13-2018, 10:34 PM   #3298 (permalink)
EV
I haven't had time to work on this in a long time, and I don't see myself getting back into it any time soon unfortunately.
If anybody is interested, I'd sell my fully assembled inverter board for $100 shipped. I feel like that is fair for what is essentially an untested board. It has always been stored inside an anti-static bag and that is how it will be packed.
I was never able to establish communication, and I was unable to determine if that was because of my lack of experience with PICs, a faulty knockoff pickit3, or an issue with the board itself.
PM me if you're interested. I'll only ship within the continental US.
Old 11-14-2018, 02:58 AM   #3299 (permalink)
jackbauer's Avatar
PM sent. Very interested in this.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 11-14-2018, 07:21 AM   #3300 (permalink)
PM sent. Also very interested.
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7377 11-12-2022 11:23 AM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 01:59 PM
