Upon closer inspection of the plug I found one of the proximity or CANbus pins had fallen out.
Edit, I think the chademo only uses 7 of the 8 small pins.
It looks like receptacle on the car doesn't have jack guts in that spot compared to the other 7 jacks.
I went to see if the pin had broken off in the car and it doesn't look like there is anything in that spot for a pin to make contact with.
