Thread: Home CHAdeMO
Old 01-24-2019, 06:07 AM   #43 (permalink)
oil pan 4
Still broke. Customer service from setec appears to be nonexistent.
More checks I can do on the analog side are check for 12v on pin 2 and 4, make sure pin 1 has ground contact between the vehicle and charger
Also when I try to connect the chademo then check leaf spy the number of quick charges remains the same. So the connection between the chademo is never being established, I didn't think it was but this confirms it.
aerohead (03-20-2019)
