Old 01-25-2019, 11:40 AM   #251 (permalink)
Piotrsko
Originally Posted by rmay635703 View Post
My Volt has a max of about 50 miles driving normalish with 10.5kwhrs available
If you are going 100 miles you are likely using more than 15kwhr of juice
Duh!
Wasnt comparing ranger to electric ghia, was comparing battery packs based on incomplete picture of back seat using swag engineering back estimating what the pack was.
15 kwh is 50% more than 10kwh so 75 miles in a volt is an acceptable napkin equation which I indicated
Ranger also goes 40 miles in the flats using a 2011 volt pack. Cd is brick shaped which affects freeway range significantly.
