Old 01-30-2019, 10:55 AM   #182 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Originally Posted by RedDevil View Post
Seems they need constant, or at least very regular balancing.
Top balancing does not cut it, unless you charge very frequently. Mini solar panel?
I think top balancing is ok so long as the balancing Is aggressive enough, and occurs in the range they typically operate in. The LEDs I chose only balance when the caps are above a certain voltage, and while sitting I'm sure they were below that for much of it. The longer they can sit near full without cycling, the more they'll stay in balance. A higher current LED would help.
