Question time : Do I need to use 3 current sensors? or will two suffice. From what I can see the fault logic at least requires 3 current sensors.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
