Old 02-04-2019, 04:22 PM   #3318 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by jackbauer View Post
Well, I fitted a 3rd LEM and the inverter burst into life. Now outputting 10khz pwm on all 6 channels. Now I just need to figure how how to make it turn a motor ...
If you load up my parameter file, it should run with a potbox throttle on pretty much any AC induction motor.
There may be a bit of overshoot on the torque command ... and you'll have to set your encoder pulses per revolution .. but it should spin unloaded
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
