I'm using a hall throttle and so far no luck.
Have configured throttle.
Motor and HV connected.
Confirmed mechanical speed in both direction being read when motor turned by hand.
No global faults and all igbts switching at 10khz but throttle has no effect on pwm generation and no current being generated. I suspect something is holding off the current generation but struggling to find it.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
