Old 02-05-2019, 01:27 PM   #3322 (permalink)
jackbauer
jackbauer's Avatar
I am using mplabx. quite easy to setup and use :https://www.microchip.com/mplab/mplab-x-ide
Regards the hall effect throttle, I am using one from a bmw e46 that outputs between 0.65 and 4.3v so I just feed this into the throttle input and give it +5v and ground then workout the calibration as normal. No need to mess about with resistors at all.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
