Old 02-07-2019, 12:11 PM   #207 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Originally Posted by hayden55 View Post
Sounds like you need a low voltage cut. Maybe if you're starting current is low enough with the caps you could find a low voltage cut with an appropriate rating.
https://www.amazon.com/Volt-Voltage-.../dp/B00KI1Z8TY
I've read that a starter might be expected to draw 80-120 amps average, but that the initial current rush could be as high as 4-600 amps.
