Old 02-07-2019, 12:17 PM   #71 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
In short-to-mid term, 48V systems seem to be somewhat of a low-hanging fruit that will eventually make its way even in entry-level cars.
I expect 48v system to become standard equipment shortly.
Well, even if some accessory such as an EPAS or an A/C compressor can be driven with 12V, a 48V system provides the same power with fewer weight. Another advantage, even though some small places to take a handful of ounces out of a landyacht may look negligible at first...
The difference is that with 48v you can run the A/C while the engine is off. It makes stop/start technology much more effective. Lower weight is another andvantage as is smaller diameter wires.
