EVTV Motor Verks Store: Torque Box 2:1 Gear Box, Drive Train Components, torquebox
Simplify and add lightness. This will lighten your wallet by $3500.
Originally Posted by ModNewb
Based on my calculations, if you go the serial hybrid route, you'll need a generator that put out 15-30 KWh for a light vehicle (3500 lbs or less) for highway use, unloaded.
That would be one or two Impala/LaCrosse 20hp altermotors.
https://ecomodder.com/forum/showthre...tor-35003.html
Is it TOO LATE to build a plug-in Hybrid Pickup truck?
The video is from 2012. I haven't made much progress on my EV conversion either.
