Old 02-13-2019, 01:36 PM   #1 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
accurate temperature measurement
I just bought an interesting bit-o-kit.
Features
• Compatible with any of our EGT probes & CHT sensors
• Accepts up to12 probes
• High resolution LCD display with backlighting
• Temperatures can be displayed in °C or °F; from -100 to +1200ēC (-148 to +2192°F)
• Display up to 12 channels in an easy to read bargraph format
• Visible high temperature alarm; LED changes to red color
• Recall Max Peak temperature memory Button
• Power from either 12 VDC or 24 VDC
• Supports J, K, & E thermocouple probes
The 12-channel digital thermocouple pyrometer gauge display is 3-1/8” instrument that contains all the features necessary to monitor EGTs and/or CHTs. The instrument is fully programmable by the user resulting in the most flexible solution available. The gauge display can be configured to display up to 12 thermocouples in an easy to read bargraph format.
12-channel-digital-thermocouple-pyrometer-gauge-display
exhaust-gas-temperature-EGT-8-probe-harness-severe-duty
Features
Engineered for high horsepower applications!
• EGT-IP series
• Set of 8 EGT probes • Probe diameter 1/4 inch (0.250 inch)
• Exposed Tip Sensing Junction (Fast Response)
• Response time constant: 150 milliseconds
• Includes 316 SS adjustable compression fitting
(Recommended for fuel types: Gasoline, Nitromethane, & Alcohols)
I ordered 12 total 1/4" 125 ms response EGT K-type probes (125 ms to respond/start to react will take 5X the response time to read full. AKA 125ms =625 ms/ .625 sec) other more common response times 250,550, and 1200 ms.(1.25, 2.7, and 6 sec) the gage has a 1 sec refresh rate. The more comin probes need 1-6 refreshes to show engine damaging overheat condition.
I have a 6 cyl, so 6 ports will read individual cylinders 3 will measure intake air ambient (pre turbo), charge air (pre intercooler), and intake air temp just under the grid heaters in the manifold.
i also got (all with 12' leads)
some weld on probes
some stick ons
what would you like to see tested ?
oil temp rise compared to coolant temp rise.
how the grill block effects coolant , oil, trans , under hood/ IAT
What do you think ? Did Cummins properly balanced the fuel sys AKA each burning at the same air fuel ratio/ temp (the richer the hotter/ smokier)
Dream Big Chisel Down To Reality
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
Daschicken (03-20-2019)
