Do you know if it requires periodic calibration and at how many points on the scale? I'm not even sure how you could calibrate it, you would need to accurately measure the same sample with a second device that is, presumably, more accurate.
Maybe the easiest thing to do would be to periodically check for agreement for all the sensors. At ambient then in a fire/oven? Idk
