Old 02-13-2019, 09:38 PM   #3 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Originally Posted by ksa8907 View Post
Do you know if it requires periodic calibration and at how many points on the scale? I'm not even sure how you could calibrate it, you would need to accurately measure the same sample with a second device that is, presumably, more accurate.
Maybe the easiest thing to do would be to periodically check for agreement for all the sensors. At ambient then in a fire/oven? Idk
If I recall correctly it has an auto calibration function.
Touch the exposed Junction to ice, you should read 32F/0C.
https://sciencing.com/calibrate-thermocouple-2659.html
For example, the voltage for a type K thermocouple at a temperature of 25 degrees Celsius is 1 millivolt....The voltage on a standard type K thermocouple should increase about 40 microvolts for every degree Celsius increase in temperature
I have a VOM that uses K type digital display, and the single chanal analog 0-1600 gage currently reading the back 3 cylinders on my truck.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
