Old 02-21-2019, 09:53 PM   #40 (permalink)
Taylor95
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
As far as I know, the Model S is the only model. It was in response to a Tesla fire that was determined to be caused by something penetrating the undercarriage of the car. Perhaps they built a tougher undertray in the proceeding models.
What is there to neglect maintenance wise with an EV? Wiper fluid? Wipers? Tires?
You seem to be looking for ways to cast EVs in a negative light; ways which don't make any sense. There's plenty of reasons to not want an EV, such as the higher cost, the limited range, the slow charging... there's no need to create a false perception that they are also high maintenance or particularly prone to fire.
Is saying that there will be required maintenance casting EVs in a negative light? I don't understand your thinking. And I never said that they are more prone to fire.
There are plenty of things that will need maintaining in an electric car. Things like brakes, wheel bearings, suspension, steering, and battery cables. As EVs are developed to have more range they will likely be liquid cooled. I'm sure some already have this. Also shocks go bad over time, and there are also lubricants in the drivetrain. Over time parts in the motor will likely require replacing as well.
