Old 02-23-2019, 02:14 AM   #119 (permalink)
freebeard
I like the fins on your Insight. How did you adhere them to the glass?
I've always been curious about the logic behind the canted and slotted fins on the Bertone BAT
https://en.wikipedia.org/wiki/Alfa_Romeo_BAT
I thought that while in free air a car body might rotate around the Cp, the tire contact patch wants to rotate around a point ahead of the rear axle line. So there would be a hidden moment of force there. Also, you might have included mention of NASCAR roof-top fences in the subject.
_________________
At Permalink #105 I'd asked what you thought about the magic butt trumpet exponential bell difusser.
I was searching for something else and I found a thread from 2016 where a forum member, stealth, applied CFD modeling to the question. Here's the result:
On the model that has 100mm of ground clearance, flat base, removing the inverted horn increased the drag from 5.4N to 5.9N, increase of almost 10%. The pictures shows that without the airflow that going through the horn and pushing up the wake, it allows the airflow from the top go down and push aside all of the other airflow.
However what's interesting is that for the 30mm ground clearance, the drag values are near identical. I think this is because of the size of the horn and the low ground clearance makes for a rapid expansion of the airflow which has similar drag level to having a solid back end.
It all depends on the size of the horn and the ground clearance but I think it can be used to reduce the drag if done correctly. In terms of the Cd accuracy, in terms of real world predictions, the software wouldn't be any good unless I can get some real world validation, but it's accurate and consistent for when comparing designs and their drag values.
My interpretation is that the second picture has the flat transom and the third has the bell. It appears to add order to the lower part of the wake. And with +70mm of air moving, 10% less drag.
