Old 02-25-2019, 07:00 AM   #329 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
I want to say that while the Insight's engine can crank out ~67HP at 6000rpm, it's probably only making around 22HP with the throttle wide open at 2000rpm. The 2004 Prius 1.5L is ~76HP at 5000rpm, so you're looking at a little over 30HP at 2000.
Check out the Base Specific Fuel Consumption thread for info on throttle position vs efficiency.
deluxx (02-26-2019)
