Old 02-26-2019, 12:50 PM   #97 (permalink)
redpoint5
90 day: 38.47 mpg (US)
That's what it says. You can't even add a single light, garage door opener, can opener, ect to the evse circuit.
I haven't read the code, but I don't think it says an EVSE must be on a dedicated circuit. My guess is if the EVSE is permanently installed, the circuit must be on a dedicated circuit.
Nearly all EVs come with L1 chargers that are designed to plug into standard outlets with no dedication to the EVSE.
Another problem is creating a billing infrastructure attached to the light pole. It needs to measure energy consumption and be connected to the internet to authenticate the user and bill them.
Originally Posted by Taylor95 View Post
That would be a really long time. Like, not in any of our lifetimes...
Plus there's a lot of things that make complete autonomy unlikely at this point. Will all cars be connected to a cellular network? What about areas that are out of range?
If your definition of autonomous vehicles is so-called level 5, then I agree with you because there will always be situations where a human needs to override the programming. If your definition is level 4, where the car normally has control, but the means to override are available, then I disagree.
Tesla is already at level 3, and most cars in the very near future will be L1 or L2 as standard equipment.
People continuously rate safety as their #1 criteria in choosing a vehicle. As autonomous features prove to increase safety, they will be adopted.
I will live to see the day when airbags and seatbelts are no longer required equipment.
