Old 02-26-2019, 01:10 PM   #98 (permalink)
oil pan 4
NEC 625.29 states the EVSE shall be plugged into the receptacle and not be plugged into an extension cord.
NEC 210.17 states that a receptacle used for charging an electric vehicle shall not contain any other receptacles. Each electric vehicle charger is to be on its own dedicated circuit.
Doesn't matter if it's 120v, 240v evse or something like a chademo.
NEC 240.4 requires a 15 amp breaker on a 14 gauge or heavier wire and a 20 amp circuit must use at least 12 gauge.
Xist (03-04-2019)
