Old 02-28-2019, 05:10 PM   #126 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Originally Posted by RedDevil View Post
So there was something wrong with the assembly. So much for trying to make things modular; apparently that caused it to fail.
I thought you said the pack didn't fail and I didn't read the article you linked?
Edit: The article does not say the cause of the failure.
300,000 miles in 3 years is not a normal use case, but there's no other way. There are no 10 year old packs made in 2015 yet. The factor age had not been sufficiently tested as there is no way to speed up time.
You could just say we don't know instead of claiming that battery replacement isn't an issue.
