Old 03-09-2019, 06:31 AM   #5 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
The major difference between EX and HX transmissions is in the final drive. Swapping the 5th gear would help but I think you're still going to lose fuel economy on the highway.
*However* pulse and glide can largely eliminate losses from too-short gearing, if you're willing to use it.
I'd personally use an HX transmission if I had your car. If you need more power you always have a lower gear, with the exception of first.
EcoCivic (03-09-2019)
