Originally Posted by 59Morris
It looks like I'm in the same position as the previous two posters. I believe everything is hooked up correctly. Using the "stream" command I have verified the throttle, temperature sensor and encoder are working as expected. When I "run-pi-test2" it does not drop to zero but stays very close to 512. Nothing I have tried so for has made the motor turn. No error messages on startup except the one that says its not really an error.
Does anyone have any suggestions as to what I might have missed??
(I'm testing with a 50 volt battery pack)
