Old 03-14-2019, 04:13 AM   #5 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Got my kit
The best part is the probs will work with my vom( volt ohm meter), not just the gauge for automotive use.
Life has been hectic. Will have to delay install till after the Allison transmission conversation is done as it is taking most of my spair time and brain power.
What 3 years and 75k mi looks like on an exposed tip k-type prob.
The new probes ×12 . 1 for each exhaust port and whatever else I went to measure
as close to the exhaust valve that I can get them. Red dot is the proposed location, head side of the manifold gasket.
Prob data sheets
Surface mount stick-on probe×2 500mS k-type.
Surface Temp. Braze or Weld on ×2K-Type 300mS
Exposed tip probs×12 150mS.
No data sheets on theas×2 6.5 " k-type probs .
KSA8907 I got a chance to read the manual
Points on the scale ? All of them , LoL.1°c/f steps.. for K-type -148°f to 2192°f which is what I will be using, the gage is also compatible with J type and E-Type
"accuracy +/-5° over full range. Subject to quality of probe used."
Calibration . "Fully cold Junction compensated using a precision internal temperature reference and built-in thermocouple linearization tables. "
Sometimes it takes a bigger hammer but always dream big chisel down to reality
Name:	Surface mount stick-on probe 500mS k-type.jpg
ID:	25637   Click image for larger version
Name:	Surface Temp. Braze or Weld on K-Type 300mS.jpg
ID:	25638   Click image for larger version
Name:	Exposed tip probs×12 150mS.jpg
ID:	25639   Click image for larger version
Name:	6.6in shilded prob.jpg
ID:	25640   Click image for larger version
Name:	Close up of the exposed tips.jpg
ID:	25642   Click image for larger version
Name:	Egt probe proposed position.jpg
ID:	25643   Click image for larger version
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
