Originally Posted by JSH
True but using the brakes gently at 7 mph or less is different than normal use. Both of my 2nd generation Prii had trouble with the rear brakes. They would lock the first stop after a rain unless I put the car in neutral and aggressively braked to break them loose. My father has had to replace the rear calipers on his 2010 Prius because they seized. I haven't had any issues with my Spark EV but it is only 3 years old and Oregon doesn't use salt.
Just because hybrids and EVs use their brakes less does't mean they are maintenance free. My Spark EV still requires the brake fluid to be replaced every 3 years like any other car. Steel brake lines will still rust and rubber ones will still age and fail, and caliper pistons will still seize.
IIRC, max regen in the 3 is something like 60-70kW compared to max output of 200+kW, and avoiding brake use takes more self control than most have.
