Originally Posted by Ecky
I get lean burn when it's subzero outside.
The only factor that absolutely stops it seems to be that the engine is warmed up.
Haven't you added the resistor though to get lean burn at any outside temperature?
I thought I got lean burn any time, because I've had it when temps were in the teens (lowest it got in Michigan while I was there), but I had two episodes of 2-3 minutes where I couldn't get lean burn on my drive down to college last night and the temp was 31 both times. I haven't added a resistor yet.
