Germany's new coal fired plant.
https://www.power-technology.com/pro...d-power-plant/
The Datteln 4 coal-fired power plant will be equipped with an advanced multi-step flue gas purification system, which will eliminate nitrogen oxides, dust and sulphur from the flue gas. Using combined heat and power technology, the Datteln 4 power plant will also produce approximately 1,000GWh of district heating, sufficient to supply for approximately 100,000 houses.
