It really was just for laughs. The sides were just on in the driveway, and I knew they wouldn't be on long so I didn't bother to use a lot of tape on them.
As for the rear, the license plate is in the window, and MI doesn't require a front plate.
The rear was just for fun too, but it held up at 50mph and didn't pull any tape off. I'll be removing the rear piece tomorrow.
The front really has a TON of tape on it, almost half the roll, and it was a pretty thick roll of tape. I think I am going to leave it on for a week or so to see if it improves anything, but if it does fall off, I'm guessing it won't just flat-out drop off the front of the car, so I'll be able to pull over and remove it easily if it gets loose or starts dragging.
Also, if it rains, everything will be removed ASAP, bacause believe me, wet blue tape is NO fun to remove.
