Old 03-31-2019, 11:04 AM   #5503 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
In a way, diesel and unleaded gas that we use in ours cars is what is leftover from refining oil and taking out all the other products we rely on just as much as motor fuel. What saved the whales wasn't any Greenpeace campaign but the discovery ground petroleum products were just as good, more plentiful, and easier to produce. No need to kill whales. So if we don't produce any oil what about rubber, asphalt, plastics, modern fabrics, etc. Propane and fuel oil has to go too. Right now it's a perfect balance, if you remove just the transportation portion you still have to drill and refine just as much oil to provide the other products. You just end up with a lake of unused gasoline and the price of everything else rising to cover the waste gasoline.
The Following 2 Users Say Thank You to Hersbird For This Useful Post:
aerohead (04-03-2019), slowmover (04-02-2019)
