Actually cat converter s IMPROVE exhaust flow because they heat it back up
Doesn't mean the intake is original.
Live in a HOA/condo/ apartment complex?
Cam change is done through the water pump part of the block no intake removal required. Do need to pull valve covers for lifter pushrod access
