Old 04-05-2019, 01:50 PM   #3368 (permalink)
Quattro64
Hello, I just stumbled onto this thread as I am doing some pre-planning for an experimental airplane build. I found Paul's instructable for this also. Just wondering if a custom inverter/controller could be built following this thread that would work for the EMRAX 348. The low voltage version of this motor with a battery pack in the 200-300v range should be able to directly drive a propeller at the required 2500 rpm range. The Emsiso EmDrive 500 that is recommended is only capable of around 110v.
Not sure how much $$ the Emsiso drive goes for, I might be able to run two in series? Seems building my own could be a cost saver? Thanks for anyones' thoughts on this.
