Old 04-15-2019, 11:18 AM   #3381 (permalink)
Piotrsko
If you keep everything at the same voltage levels, only a couple of percent for each conversion ac/dc, dc/ac. When you switch to higher voltage at one end, the losses get bigger depending on methodology.
