Old 04-15-2019, 07:23 PM   #3382 (permalink)
Quattro64
Thanks, Is it Volts or Current that I would combine, in parallel?, to increase power when I want to add battery boost? I imagine I'd need to do this prior to the controller(s) via high voltage relays or something. Is this the way I would go about adding boost to a Series Hybrid EV?
I only need to size the ICE HP to the correct sized AC Generator that would then provide converted DC to the Controller/Battery charger to both charge the batteries, preferably on the ground, and drive the AC propeller motor with decent cruising speed/power. The Battery bank would only need to be sized large enough to provide boost power when summed with the motor power or to keep the plane in the air if the motor should fail. I think this is all doable just need to crunch numbers before I start writing up any white paper.
