Old 04-23-2019, 01:25 AM   #53 (permalink)
jeff5may
Send a message via Yahoo to jeff5may
Originally Posted by pete c View Post
The above video talks about using CO2.
How efficent is it?
I suspect not very. Otherwise, everyone would use it.
CO2 isn't a bad refrigerant gas, but the problem is that it has a whole lot more pressure inside the system. Where a typical auto AC system might reach 300 or so PSI, a carbon dioxide system operates above 1000 psi. It can't be done with an existing system as a retrofit, new components must be installed that can hold up to the very high pressure.
The Following User Says Thank You to jeff5may For This Useful Post:
EcoCivic (04-23-2019)
