Old 04-25-2019, 11:54 AM   #144 (permalink)
oil pan 4
New mod.
Insulation for my garage and close in the bare studs with 7/16 OSB.
Insulation will be accomplished with a combination of A+B spray foam, fiberglass insulation, reused materials and rigid construction insulation foam.
A light spritzing of spray foam will be added to where the studs meet the exterior OSB then covered over with fiberglass or reused materials. Reused material are only used where there is no electrical running through the wall or outside contact.
Anything in contact with electrical wires, receptacle or light fixture box, a vent or is some how open to the outside a listed fire resistant insulation material will be used.
I did not spray foam under or at the bottom of Windows or near the bottom part of the garage doors.
