Thread: Evans Coolant
Old 04-26-2019, 08:22 PM   #20 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by IsaacCarlson View Post
I don't see it as a good replacement unless you are making long trips. The initial cost, coupled with the possibility of having a leak is just not enough to justify it for most drivers.
Also that it doesn’t cool very well (about half as well) and is much thicker than water.
If you have lots of cooling and not driving city it’s fine and it should gain FE because you run hotter temps but you can also wear out your engine faster and need higher octane if your motor naturally runs on the hot side. (Oil thins out with heat, preignition intensifies at temperature)
