Old 04-30-2019, 02:47 PM   #25 (permalink)
Angel And The Wolf
36x67" on a 40" frame. The square frame under the rounded carrier is suboptimal. The carrier is probably thermoplastic and can't be widened.
Yes, well I plan to lngthen the box frame by 19" and put 3/4" plywood under the carrier.
While you're lengthening the deck you could narrow it to 32".Else just put a skirt on it.
I'm sure you meant "36". I have thought of using the extra plywood to build a lead up ramp to the fenders, and possibly a side skirt on hinges so I can change the tires. Not sure if the side skirt's extra weight is worth it.
Name:	Trailer Stretched Frame With Carrier.JPG
