Old 05-11-2019, 03:36 PM   #5813 (permalink)
aerohead
solar forcing
*Pre-1999 radiometric data was off by up to an order of magnitude.
*The data represented is non-factual.
*While solar irradiance is certainly a factor in climate,it is not the driver.
*The ozone layer acts like a living 'iris'.Higher irradiance photochemically produces higher concentration of ozone,which blocks the increase in UV radiation reaching the ground.When solar output lessens,ozone,an unstable molecule to begin with,biodegrades,reducing the ozone concentration,allowing more UV to reach the ground.
*The amount of UV insolation at ground level regulates the amount of infrared radiation in the troposphere,where the 'climate' is.
*Higher concentrations of CO2 and Methane block the infrared's ability to radiate to space,warming the planet,exactly like Venus.
*Paleoclimatic records show that all warming events were always accompanied by an increase in atmospheric concentrations of greenhouse gases.
*Average,mean,global surface temperature has continued to rise since the onset of the Industrial Revolution.
*As the Sun has grown dimmer the planet continues to set heat records.
*Local and regional variability in temperature is not an unforeseen phenomena of anthopogenically-induced climate change.
