Old 09-08-2008, 09:48 PM   #567 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
UG.
Tried doing some more work on the car. (yep, raining today too.)
Very frustrating. I don't have a real engine hoist. The motor is too big for me to even move by myself.
Still waiting on getting the end of the motor machined.
Tried wiring up the charger - can't figure how to hook it up. The DC part is real straight forward, but the AC part is weird. It has three wires - red, black, and green! That's not right for 110v AC OR 220 AC!!!
I used the continuity tester to see which terminals connect when you turn on the power. I checked to see that those are the ones power goes to. Plugged it all in, and I just get an "Fault" error!
GRrr. Gr... grrrrr...
Actually, I did get SOMETHING done. I drilled holes through the rear battery rack into the body of the car and got it bolted down. I used threaded rod to connect a top-front angle iron to the rear bottom angle-iron, I tightened it down. That should at least keep the batteries from sliding around.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
