Originally Posted by redpoint5;598296[B
]How much would it have cost to repair the Prius? [/B]Assuming the valves weren't destroyed in the chain slip, it seems you'd only need to replace the chain tensioner and possibly the chain and gear.
I've never done it before, but it at least sounds reasonably straightforward to me.
prius?
that one needed a new stator
dealer wanted a grand to investigate (just to check if it was bad)
the Nissan, the one that broke the chain
it needed a new motor (top end at least)
I scoped one of the holes, it had valve damage
you could hear that it had lost compression
2005 GTO 6.0 V8 (600hp)
1991 Geo Metro 1.0 3/5 base
2010 Prius II (replaced 2001 Tahoe 5.3 V8 April 2014)
1994 F-350 7.3 TurboDiesel (Rollin' Coal)
