Originally Posted by slowmover
Sure do. Pickups get past any semblance of road stability at 65-mph.
A Panhard Rod for the rear axle is the usual step. (Contact SUPER STEER). An anti-roll bar also (and the front bar moved up one step in size).
Remote reservoir shocks (FOX, KING or BILSTEIN). The step up from entry level non-remote.
MOPAR used to have a kit (1970s) that fitted a shock absorber from a plate under the axle mount along the upper forward part of the leaf spring to the front eye bushing. Had to do with axle tramp, but it’d help here, too.
The lack of a stock front sway bad has also been addressed. I installed a SWAY - 134 g-max-1" front-sway-bar for 89-93 3/4 and 1ton diesel
Custom shocks and custom rear panhard are on the wish list, will be going more tord a Watts link(link to wiki) insted of a panhard bar. And for salt flat speed runs will take Aeroheads advice and run a solid rod /jack screws in place of shock absorbers. The watts link has a more vertical motion, less head bobble as the suspension cycles . Both watts and panhard will work well with the planned 4 link that is in the design phase. This wi elevate the need for traction bars/snubbers.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
