Old 05-20-2019, 02:40 PM   #17 (permalink)
hogheadv2
3 Wheel, standard big twin trans 5sp. Electric reverse ad on. Belt from engine to trans as normal primary set up with clutch. Final drive to diff from small car in bearings. Differential enclosed by metal housing. Sprocket in place of ring gear. Half shafts out to front wheels. 30% of hp stock clutch can hold, weight not much more than bike with side car.
Thank you for the input. Yes as a slick wide reverse trike.
