Old 05-24-2019, 08:53 PM   #13 (permalink)
Enviro
Don't remove the air dam.
Lower it and keep the air dam.
Would the air dam do more good than a flat belly and lowering it so the car is at the height that the air dam went to?? The underside is super gross aerodynamically and I feel like the dam can't be doing that much and a flat belly would do much more for the mpg than anything else.
Should I do a flat belly, lower it and keep the dam?
