Old 05-27-2019, 03:05 PM   #19 (permalink)
IsaacCarlson
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
I tapped the oil hole for a 1/4x28 grub screw and bottomed it on the cut threads with locktite. It's not coming out without a fight. I am able to use another 1.5-2 qts of oil, which is nice when these engines can burn 1 qt in 1,000 miles. This also helps reduce oil temps.
I will pull the shafts out of my spare motor too, when I go through it.
I need to redo the pistons on the current motor because of oil usage. And the spare will be a drop in replacement to keep the car running.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
