Old 05-31-2019, 08:36 AM   #9 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Originally Posted by Shaneajanderson View Post
O2 sensor for my odyssey is like $20. The downstream O2 sensor exists only to see if the catalytic converter is working, so actually it will throw a code if the two agree, which would indicate a catalyst failure
The downstream does act to see if the catalyst is working, but it will also throw a code if the gasses getting past the first aren't right. It's often the case that a catalyst efficiency code is actually a failing upstream O2.
