Old 06-13-2019, 12:50 PM   #876 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Honestly, this is my third aluminum boat and I haven't had any maintenance issues on any of them. Especially when you buy them cheap and in need of a repair. Once I fix them I just run 93 no ethanol, 50:1, run them out of gas when I put them up, and on occasion I change a water impeller. Fiberglass inboard though... Those ain't for the po man.
Also, this boat has the Toyota of motors and is welded = no rivets to leak.
Should have it fixed with a new prop by the weekend. All in should be $2050.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
slowmover (06-14-2019)
