Old 06-14-2019, 08:47 AM   #8 (permalink)
Spaghetti Man
Originally Posted by Ironside View Post
The linkage bar is a 6mm threaded bar inserted into a ss tube (tubes don't flex). End joints and levers are standard motorcycle fitments, threaded bar fits the theads on the rose linkage.
Good stuff. I have had a little bad experience with linkages so wanted to make sure I get a proper size.
Originally Posted by Grant-53 View Post
Once you get the bike set up the way you want, have someone help weigh it at both wheels with you aboard. This will help determine the the center of mass. The center of pressure for the shell should be aft of the center of mass. The HPV body shell software at recumbents.com is helpful.
Sounds good.
I have bought the bike so now I'll get started with the plan.
