Old 06-18-2019, 11:15 AM   #2 (permalink)
samwichse
Thalmaturge
CHONK - '18 Honda Clarity
Well that's a hell of a first post.
I looked it up, and
https://www.microchip.com/design-cen...chronous-motor
The Permanent Magnet Synchronous Motor (PMSM) is an AC synchronous motor whose field excitation is provided by permanent magnets, and has a sinusoidal Back EMF waveform.
SVM is Space Vector Modulation
https://www.mathworks.com/solutions/...ransforms.html
The Clarke transform converts the time domain components of a three-phase system (in abc frame) to two components in an orthogonal stationary frame (αβ). The Park transform converts the two components in the αβ frame to an orthogonal rotating reference frame (dq). Implementing these two transforms in a consecutive manner simplifies computations by converting AC current and voltage waveform into DC signals.
None of this is helpful to you, but yay! I'm learning. Hopefully someone more knowledgeable then me will be along shortly.
The Following User Says Thank You to samwichse For This Useful Post:
Xist (06-21-2019)
