Originally Posted by Vekke
You need to adjust your torsion value. like this and you need also vag com cable. It will do miracles to your low end torgue and fuel consumption.
If you want to get better ecu program I can help you out on that too for little cost.
I've one experience of tuning TDI engines, and have the cables/mapping software - I may play about with it at some point
