Old 06-26-2019, 12:02 PM   #80 (permalink)
Shaneajanderson
Redneck Ecomodder
How do you catch the liquid?
Since the bolt extractor worked, I will order the fasteners, and file this away under... I will probably forget it.
I'm not sure what you do with the solution when done, probably pull the tray off the engine, clean up the silicone and give everything a good rinse. The alum solution takes a week or so to dissolve a bolt, so it's not like you're going nto bore a hole in your block by letting it run down the side.
If the bolt extractor worked, bravo, the alum thing would be the last resort in my book.
